Sponsored by:
Sponsored by:
New timing belt & water pump. Now new oil leak? '95 Camry
Old 09-12-2005, 12:49 AM
lesaroka's Avatar
Default New timing belt & water pump. Now new oil leak? '95 Camry
I JUST HAD THE TIMING BELT AND WATER PUMP REPLACED ON MY '95 CAMRY WITH 98.000 MILES. THE BELT WAS WORN BADLY AND PROBABLY VERY CLOSE TO BREAKING. THE NEXT DAY I NOTICED A NEW OIL LEAK ON MY GARAGE FLOOR. THE LEAK IS NOWHERE NEAR THE TIMING BELT AREA BUT MORE TOWARD THE CENTER OF THE ENGINE. DOES ANYONE HAVE A POSSIBLE EXPLANATION? HOW COULD A NEW TB AND WP CAUSE AN OIL LEAK?
THANKS
Old 09-12-2005, 10:58 PM
Greg55's Avatar
Default RE: New timing belt & water pump. Now new oil leak? '95 Camry
Just my 2 cents, maybe they disrupted the oil pan a little when they did the front of the motor. I haven't been under my Camry lately but the oil pan could have a couple of bolts into the front of the motor. The oil could be running down the pan and dripping in the center. Try wiping the pan and the underside of the motor and may be you'll be able to see where the oil comes from. My experience is and has been changing the oil on 6 different years of Camrys, a 4 Runner, 2 Tacomas, and 2 Corrollas. I've seen the underside of many engines. I agree that it is unusual for an oil leak on a Toyota but something is definately going on under there. Again only my 2 cents.
hardlymoving
08-29-2019 01:51 PM
elvis1977
03-08-2011 01:16 AM
hardlymoving
07-28-2010 06:28 PM
Linux
08-03-2009 10:43 PM
kingcat
01-16-2009 07:36 PM
Quick Reply: New timing belt & water pump. Now new oil leak? '95 Camry
