Sponsored by:
Sponsored by:
P0138 Resets after o2 Sensor Replaced
Old 01-07-2013, 06:13 PM
jgentle's Avatar
Default P0138 Resets after o2 Sensor Replaced
I tried searching for similar threads. 2006 Camry 2.4L. Had code P0138, id'd as the rear (behind cat converter) O2 Sensor. Replaced the unit and CEL went out. Drove 10 miles and the code reset. Any one have ideas?
Old 01-10-2013, 10:50 PM
go-part's Avatar
Former Sponsor
http://engine-codes.com/p0138_toyota.html
There are other things that cause that CEL code to show up
Old 01-11-2013, 08:41 AM
You replaced the sensor after the first converter built into the exhaust manifold but before the second converter under the car?
What brand and part number of sensor?
Old 01-11-2013, 09:37 AM
jgentle's Avatar
No it was the last o2 sensor in the string, behind the cat. Other searches point to possible PCM communications problems. Looks like a trip to the dealer.
Old 01-11-2013, 07:45 PM
Does the engine have two cats, one being built into the exhaust manifold and another under the chassis?
If so the engine may have 3 sensors.
P0138 is the 2nd (middle) sensor.
Glenn
05-23-2015 12:05 PM
zeddsdead
11-15-2012 01:12 AM
henrydhiggins
12-13-2007 11:38 PM
Monguse
10-06-2007 12:54 AM
Quick Reply: P0138 Resets after o2 Sensor Replaced
