Sponsored by:
Sponsored by:
power seat doesn't move forward
Old 08-21-2005, 10:06 AM
MR.CAMRY's Avatar
Default power seat doesn't move forward
My power seat in my 97 Camry driver'side is not working as far as moving forward...I can hear the motor running but the seat doesn't move..Do I have to replace the whole track with the electric motors? or is there a simple fix?
Old 03-08-2010, 12:36 PM
jcwagner's Avatar
I have the same problem. Was there ever an answer to this question?
Old 03-08-2010, 11:36 PM
If the motor is working but the seat does not move the gear motor or seat track might be stripped. Guessing the gear on the motor is stripped at it may be plastic.
The seat is held in place by only four bolts, one at each end of the two tracks. These may be hidden by a plastic cover the pops off. The seat wiring harness will unplug. You can remove the seat to take a look.
The forward/reverse motor is the one closest to the dashboard.
Old 09-03-2013, 11:59 PM
97CamryV6's Avatar
"take a look"?
How do you access the stripped gear hidden inside the metal track?
bobw1008
06-09-2015 07:53 AM
demiandvm54
06-16-2012 08:26 AM
scoathy
06-16-2011 01:31 PM
inter911
08-06-2008 01:09 AM
Quick Reply: power seat doesn't move forward
