Sign in using an external account
| Register | Photos | FAQ | Members | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Vendors | TSB & Recalls |
LinkBack | Thread Tools | Search this Thread |
__________________
92 Camry XLE V-6 |
The switch probably has one wire while the sensor has two.
__________________
95 2.2L LE Wagon Auto Trans 150,000 miles. |
They both have the exact same two wire connecter on them.
I bought the Coolant Temp sensor but when I went to replace it, the threads were too small. It wouldn't fit the thermostat housing. So I looked at the Radiator Fan switch, and it had the proper size threads, but was a little bit longer. All the manuals I've looked at only make it more confusing, cuz one will call it a sensor and the other will it a switch.
__________________
92 Camry XLE V-6 |
In my Haynes the 1MZ-FE V6 shows two water temp SWITCHES at the thermostat housing and NO temp SENSOR at all. "A" is on top and "B" is on the side of the housing. "A" should show continuity only when cold. I'm assuming Toyo is using the two switches as an alternative to a sensor. The difference in thread is so as not to be able to mix them up.
__________________
Great... my problem solved... thanks.
Hello,
service for friends, family, and co–workers to communicate. Thanks..... ------------- Buy Low price auto parts for Toyota, Honda, Mitsubishi, Nissan, Pontiac, Mazda, Lexus, Jeep, Honda,Dodge, Ford, Audi, Acura, GMC,Volkswagen and many more at theautopartsshop.com Auto Parts – Toyota, Honda, Mitsubishi, Nissan, Volkswagen Parts at theautopartsshop.com Auto Parts Stores Auto Parts Car Parts Cheap Car Parts Automotive Parts Automotive Body Parts Auto Parts Toyota Auto Parts Honda Auto Parts Mitsubishi Auto Parts Nissan Auto Parts Volkswagen |
| Tags |
| 22, camry, coolant, engine, fan, located, radiator, replace, sensor, switch, switchsensor, swith, temp, temperature, toyota |
