steering rack guide adjustment
I am trying to make an adjustment to the rack guide screw on my 98 Camry LE to tighten up my steering and I looked on my car and found a hole where the guide screw and locking nut is supposed to be. I looked into this because my steering is really loose, but it looks like before I can make an adjustment to the steering rack I will first need to buy a replacement rack guide, spring, guide screw, and locking nut (do you know of any other parts I will need here?). Do I just need to insert the rack guide, spring, guide screw and locking nut and adjust or will there be more involved to fix this?
i brightened up the picture
it may be the type of adjuster that has two slots and a lock nut and no hex
there isnt much adjustment on the pinion part at that point
if no improvement with an adjustment ..a new rack is recommended
.while trying to work out what was going on there
i had a picture of the slot and lock nut rack and pinion system...... didnt save it
your picture
if there is a lock nut to undo
try this
use a screwdriver or something that works in the grooves , to hold it in place
you undo the lock nut
turn the slotted adjustment inwards a 1/8 turn only say 10 deg s
(this loads the spring up a bit more )
hold the adjuster in place and do the lock nut up
test steering
if it needs more..... replace the rack
your picture
try this
test steering
toyomoho, could you scan that page so I can see what you're describing? Could you also scan anything in there about the steering rack and especially about the rack guide or any adjustments to the rack and pinion? I'm hoping that a service manual might shed some light on this matter as there is very little information about it on the web. Thanks.
