Torque Specs for Rear Wheel Hub Mounting Bolts - Camry Forums - Toyota Camry Forum
Thread Tools Search this Thread
Old 11-12-2011, 10:36 PM
Default Torque Specs for Rear Wheel Hub Mounting Bolts
Hello:
As I remount a new rear wheel hub onto the left rear bracket I was going to use antiseize on the bolts. Is this OK? Also, what are the torque specs for these bolts so I tighten them properly-for after all, they do hold the wheels on. Thank you for all your help to a newbie, I do appreciate it.
Michael
2003 Camry 4 cyl XLE
Old 11-13-2011, 04:15 PM
59 ft-lbs
If you use anti-seize compound the torque will no longer be valid, the compound will act as as lubricant. If you want to use it on the bolt portion OK but not on the thread portion the nut will contact.
Old 11-13-2011, 09:14 PM
Default How Does Antiseize Affect Torque Values?
Hello:
I ended up having some antiseize already on the bolts so when I torque them to the required value ( I wiped off what I could ) I really am tightening them to a higher value due to the lubrication effect, right? Correct me if I am wrong please.
Michael
Old 11-14-2011, 09:39 AM
Torque is used to obtain a desired clamp up force, the force of the bolt pulling the parts together.
Unless noted in the manual, etc, bolts are installed without lube.
Antiseize compound being a lube will increase the amount of clamp up force.
In theory when using antiseize the torque value should be reduced by 2/3 to 3/4.
If you removed as much of the antiseize as possible would not be concerned in this case.
However if doing something like head bolts (often the manual states to dip the complete bolt in oil) or a nut that preloads a bearing then would concerned as the clamp up force will be increased.
Thread Thread Starter Forum Replies Last Post
04 Camry XLE Rear Wheel Hub (Disk Brake) eyeblazin Suspension, Brakes, Tires & Wheels 4 05-13-2013 12:36 PM
Removing 2003 Rear Wheel Hub ABS Clip? demiandvm54 General Tech 1 11-12-2011 10:39 PM
Rear Wheel Hub Assembly Question demiandvm54 Suspension, Brakes, Tires & Wheels 3 11-10-2011 07:48 AM
Rear Wheel Hub Assembly Question demiandvm54 General Tech 1 11-08-2011 08:13 PM
Wheel lug torque specs--2010 Camry XLE millerl513 DIY - Do It Yourself 2 05-26-2010 09:59 AM
Tags
2000, 2003, 2010, 2011, antiseize, bolt, camry, effect, hub, rear, spec, specs, torque, toyota, wheel
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
