Trans problem
RE: Trans problem
Determine if the shift arm on the side of the trans is moving in sync with the shift selection console, the cable can break.
If OK a few causes could be a bad torque converter clutch or plugged oil intake screen. The pan can be removed to check the screen. Also completely change the fluid (about 6 quarts). Do about 4 drain and refills with a few miles in between to get most of the old oil out, about 2/3rds is always in the converter.
Stryperfan
08-20-2008 05:33 PM
