Sponsored by:
Sponsored by:
VSC, Traction & Engine Light
Old 01-15-2017, 04:32 PM
winwabuwe's Avatar
Default VSC, Traction & Engine Light
I drive camry 2007 XLE V6, after driving for 20KM VSC, Traction plus engine light came up and engine start vibrating/ jerking, I stop put off the engine and remove the positive battery terminal then replace after 30 seconds but all the VSC, traction light came up again plus engine light blinking... please what should I do. Thanks
Old 01-15-2017, 07:17 PM
dirty hands's Avatar
good DIY try ..when Clearing the fault codes hasnt worked
diagnostic scanner with its codes saves guessing and will point to which sensor
Old 01-15-2017, 09:54 PM
A blinking Check Engine light signals an engine problem that can damage to the emissions converter. Typically this is due to a misfire causing a rich mixture and the converter to over heat.
Suggest NOT driving the car until the problem is fixed.
The VSC and Traction light will come with check light to minimize engine power needs. Most likely engine problem perhaps ign system.
Get codes read as suggested. This is your easiest route to find the problem quickly.
Old 01-17-2017, 01:00 PM
winwabuwe's Avatar
Default scan Camry Results
I scan my Camry 2007 XLE today as directed and below are the result. What is your recommendation
PO300 - Random Multiple Cylinder Misfire detected PO302 - Cylinder 2 Misfire detected
​​​​​​​PO304 - Cylinder 4 Misfire detected
Old 01-17-2017, 11:35 PM
Check ignition coils, grounds for ignition system, plugs.
CTK
09-28-2016 06:26 PM
ashleilynn
09-17-2012 11:52 AM
carlkra
02-01-2009 04:58 PM
FamilyGuy
11-05-2008 11:30 PM
chigato
01-07-2008 04:27 PM
Quick Reply: VSC, Traction & Engine Light
