BLINKER PROBLEM
Old 12-23-2006, 11:16 PM
blackonblackLECOUPE's Avatar
Default BLINKER PROBLEM
Hi, new to the site so I hope someone can help me out here...
I have a 1994 Toyota Camry LE Coupe w/ 2.2L
My blinkers don't work...however, the blinker bulbs work when the parking lights are on, the turn signals dont work...when I flip the turn signal lever...nothing happens
I couldn't find the blinker fuse, anyone know where it is or what my problem is???
Old 12-26-2006, 10:18 PM
tim96460's Avatar
Default RE: BLINKER PROBLEM
Do they work independantly with the running lights on or do they all 4 work at the same time??
Old 12-26-2006, 10:57 PM
they work with the hazards and when the parking lights are on...
any ideas??? i need help so i don't get a ticket
Old 12-26-2006, 11:22 PM
tim96460's Avatar
when you say go for a left turn, does the lights on the ouside of the car come on and stay on or is there nothing at all>>??? Be very specific so I don't recommend something you don't need. What exactly have you done to troubleshooot?
Old 12-27-2006, 08:36 PM
here is what happens in more detail...
when i push the turn signal lever down/up to use the turn signals, nothing happens (turn signals don't flash, turn signal lights on the dash don't come on/blink, no blinker blinker sound, nothing)
but when i turn on the hazard's all four lights on the exterior come on, as well as the dash lights, and the blinker blinker sound is there...
i looked for the fuse for blinkers but i couldn't find the fuse...and all the bulbs work
any of that help?
Old 12-27-2006, 11:36 PM
tim96460's Avatar
sounds like an blinker switch assembly
Old 02-18-2007, 10:19 PM
ness.82's Avatar
I had the same problem on my 91 Camry, Apparently its afuse up and under your steering wheel. (sorry but i dont remember the exact name of it). My dash lights went on my car first, and than the blinkers went within a month later..
It cost about $80aus to be replaced my a mechanic and took about 20mins sorry i cant tell you the exact name of the problem.
pe3wee
11-16-2012 03:14 AM
KaFa21
01-16-2011 04:29 PM
tt837
10-07-2010 02:11 PM
moh.vze.com
03-06-2008 05:11 PM
Quick Reply: BLINKER PROBLEM
