Where to buy ignition coil and cost?
Old 03-25-2007, 01:08 PM
EagerBeaver's Avatar
Default Where to buy ignition coil and cost?
Hi,
I have a 1995 Camry 4cyl 2.2liter with a manual trans
149,000miles . I do a lot of cross country driving with it. It has the ignition coil inside the distributor cap. I was thinking of buying an ignition coil and installing it before mine has a problem. where is the best place to get one? The Toyota dealer? Thank You in advance for your advice.
Old 03-25-2007, 01:59 PM
tim96460's Avatar
Default RE: Where to buy ignition coil and cost?
Usually don't replace many coils in toyota, think the last one was a year or more ago and that one required a distributor also.
Get the yellow pages out call the dealer for cost, Napa or echlin have a pretty good track record. It is easyer to change the coil out if you remove the distributor, check that the shaft rotates smoothly with no notchy feel. Have a good philips screw driver because sometimes the screws that secure the coil are in there tight.
[align=left] [/align]
wyatt_381
03-20-2023 03:16 PM
sb87cam
04-06-2022 04:06 PM
KEVAUG
03-09-2012 12:12 AM
flores5996
10-01-2010 08:49 AM
sb87cam
05-05-2007 09:46 AM
Quick Reply: Where to buy ignition coil and cost?
