Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
2003 camry exhaust system replacement cost
Old 01-05-2020, 02:36 AM
camry4metoyota's Avatar
Default 2003 camry exhaust system replacement cost
My 2003 camry XLE 2.4L started sounded a little noisy and sometimes I can smell exhaust gas in the cabin. Dealer told me it would cost $2500 to replace the whole exhaust system because they don't so patching, only replacement. My service advisor said it might be better to find a muffler shop. So I did and still got quoted $1500. I was told only flex pipe is the problem but because it is a 16 year old car, the exhaust system is so rusted that they can't just weld a replacement flex pipe on. So they have to replace everything down from but not including the catalytic converter. I did some research on the parts on the exhaust system downstream of the catalytic converter and it appears that I need a resonator, exhaust pipe, muffler and exhaust tip. Does it sound right that replacing all these parts cost $1500 including labor? I look up prices for these walker parts and seemed to add up to just $500 - $700. Am I missing something or am I being ripped off?
Old 01-05-2020, 05:49 PM
The Toyota dealers statement follows dealer SOP. Toyota dealers do not repair exhausts but replace them.
A bad flex pipe is common. Normally the flex pipe only would be replaced at say $150+. Not sure if age is a problem but rust could be.
Suggest getting other quotes. If you can get parts for $500-700, a shop should be able to get them cheaper then you to make more profit. This means at least $800-1000 for labor which seems excessive. Try smaller owner/operator exhaust shops for quotes.
perhowell99
08-19-2015 07:11 PM
Driveshaft
10-03-2012 11:03 AM
swataz
07-05-2011 03:30 AM
not a mechanic
04-18-2010 07:23 AM
sikkim
06-16-2009 08:54 PM
Quick Reply: 2003 camry exhaust system replacement cost
