Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
P0240 Code
Old 06-28-2015, 01:24 PM
Borjogin Kita's Avatar
Default P0240 Code
Hello friends. My check engine came on the other day. It threw a code of P0240. Is there any other way to fix it before changing the catalytic converter? Any help is greatly appreciated. Thanks!
Old 06-28-2015, 03:07 PM
The link below has the list of possible issues, but for Camry the odds are it is the converter.
P0420 Error Code: Catalyst System Efficiency Below Threshold (Bank 1)
Old 11-27-2016, 11:46 AM
wdc123's Avatar
I had that problem with my Toyota 1995 Camry 195000 and 2003 Suburban 175000 My air intake butterfly was not working properly. Cleaned it, all is good.
Can remember what I used but it is for cleaning the air intake and try not to shoot inside. Also some air intakes are manual where you can move the butterfly and clean while my suburban is electronic and must be moved by pedal. It's been a while but those are the key points. Mine was filthy. If butterfly is not working right the air flow could be all messed up and hence the fuel flow. Simple first
Borjogin Kita
06-29-2015 03:17 PM
KEVAUG
06-17-2012 08:01 PM
bayarea2VZ-FE
04-27-2010 07:13 PM
mgoofy24
09-24-2007 04:56 PM
camryluvr
04-05-2005 11:24 AM
Quick Reply: P0240 Code
