1994 Camry Antenna replacement
Old 02-11-2017, 09:18 PM
carav4's Avatar
Default 1994 Camry Antenna replacement
Water has been leaking into my trunk in my 1994 Camry. I fixed the antenna drain tube but it still leaks from around the antenna mount. I am looking to replace the OEM telescoping antenna with one of a fixed length, maybe one of those short ones. Has anyone changed their OEM antenna with an aftermarket type? Which one did you use and was the install easy?
Old 02-11-2017, 09:56 PM
Have you tried putting a thin o-ring around the mount where it meets the chassis or using sealant?
CraigHutton
08-30-2017 10:39 PM
LECamry
07-12-2011 06:34 PM
skiracer
09-23-2010 12:39 PM
dantheman
08-08-2008 09:39 PM
crelwell
05-23-2008 03:23 PM
Quick Reply: 1994 Camry Antenna replacement
