87 Toyota Camry 4 cylinder manual question about power steering pump
Old 01-30-2010, 11:02 PM
hardyrxp's Avatar
Default 87 Toyota Camry 4 cylinder manual question about power steering pump
Hello Only when the car is cold and you turn the steering wheel you hear a loud squeaking noise. I checked the belt and it seems to be somewhat new and tight. I checked the power steering fluid level that is good. So my questions to you are..... Are the power steering pumps notorious for leaks or going bad in 87? What are the signs/symptoms of a power steering pump going bad? How can I find out if I can fix the noise or if I need to replace power steering pump? Have you heard of this problem or similar in a 87-91 Toyota Camry? Thanks for your help in these matters.
Dave
Old 01-31-2010, 06:54 PM
full house's Avatar
have you tried to canvass how much a steering wheel cost in your place?If its affordable try to buy new one to make sure.
Old 02-01-2010, 10:16 AM
vikram1248's Avatar
Power steering pumps can develop big leaks or can fail from general wear and tear. Aside from the power steering going out completely, several warning symptoms can occur ahead of time to let the car owner know there's a problem with the pump. Sometimes it may be something simple like fluid level being low, or a leaky hose. Changes in function or unusual noises are the main signs something might be wrong
grocerygettercamry
04-26-2012 09:53 PM
hardyrxp
02-03-2010 02:43 PM
hardyrxp
01-30-2010 11:11 PM
hardyrxp
01-30-2010 11:11 PM
cbrc5eric
01-01-2009 07:03 PM
Quick Reply: 87 Toyota Camry 4 cylinder manual question about power steering pump
