Camry 2004 4 cyl clutch master cylinder replacement
Hi,
The car's clutch peddle stuck to the floor a few times. I suspect it is the clutch master cylinder.
I want to check the fluid level on the clutch master cylinder but cannot locate a separate reservoir for the clutch master cylinder. Is it the same as the brake fluid reservoir on this car?
This car, a 2004 Camry, has a 4-cylinder 2.4 liter VVT-i engine. The manual says in order to remove the clutch master cylinder, I have to remove 1) the air cleaner, 2) brake master cylinder, 3) power brake booster, then finally get to 4) the clutch master cylinder.
I wonder if there is any short cut. At least, I want to disconnect the minimal number of hoses on the break master cylinder. I only saw one rubber hose that connects the break and clutch master cylinders.
Any pointer and suggestions will be greatly appreciated.
Here are the photos:
arrow points to the direction of clutch master cylinder.
clutch master cylinder, with a rubber hose and a metal tube connecting to it.
metal tube connection
picture from the side, I traced the power break booster and the wheel hub that limit the space for the clutch master cylinder to come out.
J2Performance
01-25-2008 11:53 AM
J2Performance
12-17-2007 03:59 PM
J2Performance
12-13-2007 11:55 AM
J2Performance
12-13-2007 11:46 AM
J2Performance
12-13-2007 11:25 AM
