Gabe TRD4life MP90 Magnuson Supercharger Kit - Page 2 - Camry Forums - Toyota Camry Forum
Thread Tools Search this Thread
  #11
Old 08-05-2011, 01:25 PM
Default 10hp
Quote:
Originally Posted by rkziegler View Post
your facebook link seems bad, but what do you have for a 2011 2.5L camry le motor? How does the SE model get the extra 10 HP? How does Lexas get even more out of it? Thank you very much.
Most likely from a revised PCM program, additional lift, duration from VVTi.
Toyota would most likely NOT reprogram PCM, but you could ask.
  #12
Old 08-06-2011, 03:50 AM
Thanks dude. I was able to use your information to find much more. First, PCM = Power Train Control Module. Next, looking at the sticker on my 2011 LE, it shows "Dual VVT-i" technology. Along the way come to find out this is a 2AR-FE engine first seen in 09 Camry's. Fun reading found here: Toyota AR engine - Wikipedia, the free encyclopedia then click on Dual VVT-i and find VVT-i, or Variable Valve Timing with intelligence introduced in 1996, varies the timing of the intake valves by adjusting the relationship between the camshaft drive (belt, scissor-gear or chain) and intake camshaft. Engine oil pressure is applied to an actuator to adjust the camshaft position. Adjustments in the overlap time between the exhaust valve closing and intake valve opening result in improved engine efficiency.[1] Variants of the system, include Dual VVT-i. Dual adjusts timing on both intake and exhaust camshafts.
Researched PCM programming and I would have to agree, that's got to be it. It is recommended for those with performance upgrades that the PCM is unable to consider. In your case, being an "SE" with 10 extra HP, don't you have dual exhaust????????
  #13
Old 08-09-2011, 02:23 PM
I was asking about superchargers and ECU's
I have a 1-MZ V6 300cc and a TRD M-62 supercharger that I am fitting to an automatic.
Is there an aftermarket ECU that you know of that will replace the original ECU with the antitheft device, that can control the automatic gearbox and managed the engine?
I want to run the supercharger at 6spi
Michael
Thread Thread Starter Forum Replies Last Post
electric supercharger beunos24 Nitrous, Super Chargers, & Turbos 5 07-30-2008 06:01 PM
trd supercharger beunos24 Nitrous, Super Chargers, & Turbos 2 07-29-2008 06:42 PM
FS: 2000 Toyota Solara w/TRD Supercharger, 5-speed, 60k miles ClarkB PRIVATE For Sale / Trade Classifieds 0 07-23-2008 08:54 PM
supercharger camryd3 Nitrous, Super Chargers, & Turbos 10 02-08-2008 01:09 AM
Ripp Supercharger? jrschultz Nitrous, Super Chargers, & Turbos 2 03-13-2007 04:13 PM
Tags
03, 1996, 1998, 2010, 22, camry, kit, kits, magnuson, mp90, sale, supercharged, supercharger, toyota, trd4life, turbo
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
