Sights n Sounds Post your video clips here.
Loud Ratting From Timing Cover When Cold
Old 01-12-2017, 04:04 PM
Jon98LE's Avatar
Default Loud Ratting From Timing Cover When Cold
Hello:
I have a 1998 Camry LE with the 5SFE.
The car has 123,603 miles. It's been making this rattling sound for a very long time that's quite loud when it's cold. The sound is most prominent between 1,600 and 1,800 rpm.
I thought this would be the timing belt tensioners for sure, so I changed the belt and tensioner last summer. I did not replace the water pump at the same time as there's one large Phillips head screw on it (why?!) and it stripped out.
I inherited this car from my grandparents who bought it new. It's been garaged and well cared for almost it's whole life with regular dealership servicings etc.
It almost sounds like the belt is slapping against the timing cover.
If this isn't the timing components, could it be the water pump?
Thanks in advance for any help!
Old 01-12-2017, 07:28 PM
dirty hands's Avatar
I can see the top plastic timing cover vibrating ..with age and heat they warp
you changed the timing belt last summer so should be no slack in the timing belt
check the bolts are tight for plastics lower and upper timing covers
there is some tappet noise there
water pump
if a screw head is stripped .. wont be an easy task to replace the water pump
with engine in the engine bay ....maybe a right angled drill chuck and drill the head out
Attached Thumbnails Loud Ratting From Timing Cover When Cold-set-up.jpg   Loud Ratting From Timing Cover When Cold-22.jpg
Old 01-12-2017, 08:20 PM
Did the water pump turn freely?
Was the belt tensioned correctly?
Old 01-13-2017, 09:45 AM
Jon98LE's Avatar
Thanks, Hands. I'll try messing with the plastic and see if it quiets down.
Toyo, yeah the pump turned smoothly and didn't feel like it had any play in it. The belt is tensioned properly.
therealzeus
01-24-2013 09:39 PM
foxyroxy111298
04-19-2012 10:15 PM
ksack001
08-01-2010 01:00 AM
howard
01-06-2008 04:47 PM
howard
12-20-2007 05:46 PM
Quick Reply: Loud Ratting From Timing Cover When Cold
