Engine noise 1998 Camry V6 - Camry Forums - Toyota Camry Forum
Thread Tools Search this Thread
Old 03-01-2017, 08:28 PM
Default Engine noise 1998 Camry V6
I have a strange engine noise that is dependent to RPM's, but only occurs when I turn the heater blower on. The sound comes from the engine compartment not under the dash. As soon as I turn the heater on it sounds like I am over revving the engine. Anyone have any ideas?
Old 03-02-2017, 11:34 AM
Is the engine RPM increasing when this happens?
Find a length of hose to use as a stethoscope. Then track down the location of the noise.
There is nothing in then engine compartment related to the the heater blower. The blower is located under the passengers side of the dash behind and below the glove box.
Old 03-02-2017, 01:31 PM
The noise only happens when I turn the fan on. The sound increases when I press the accelerator down, but if I turn the fan off the sound goes away.
Old 03-02-2017, 09:04 PM
till something fails . these types of noises hard to narrow down
could be a voltage drop off at the battery or alternator
air con compressor clutch /blower motor/ fan speed relay ?
Thread Thread Starter Forum Replies Last Post
Camry 1998 Ticking/Tapping Noise OldFox Engine & Internal 2 10-12-2012 07:28 PM
1998 camry 2.2 brake noise mkv_camry Suspension, Brakes, Tires & Wheels 5 10-15-2011 11:10 PM
Weird noise from engine and shaking of car engine 96camman New Member Area 3 01-16-2011 04:32 PM
Engine Strap on 1998 toyota camry khays General Tech 0 07-06-2008 09:51 PM
1998 Camry LE Check engine light lavalleemike ECU & Electronics 0 05-06-2006 03:21 AM
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
