02 camry rear drum to disc conversion
Has anyone heard or seen anyone convert a camry rear drum to a disc. I was thinking about doing something like this but im wondering what would it involve. Other than completely changing out most of the rear suspension components like the hub,brake lines and stuff like that. If anyone has any idea or where i can find some info on it let me know, thanks.
The easiest route is find a donor car of the same year or Generation as your car having disk brakes and swap parts. Typically this is a bolt on job. If you car has proportioning valve you will also need to change this.
The actual suspension knuckle should be the same (part that the strut and control arms attach to).
Ninja122
09-28-2016 07:56 PM
05, 2002, 2005, brake, brakes, camry, changing, conversion, converting, convertion, disc, disk, drum, rear, toyota
