98 Camry low to the ground
Old 02-29-2012, 10:19 AM
tchundley's Avatar
Default 98 Camry low to the ground
I have a used 98 Camry that I purchased last year (I'm the 2nd owner). I love the car, but the only problem that I am having with it is that whenever I have other people in it and drive over a speed bump or into my driveway (which is uphill) the bottom of the car drags. Should I put a lift kit on it, replace the coil springs, or even the shocks? I am afraid of damaging the undercarriage and end up spending more for repairs than what it would cost to solve the problem.
Old 02-29-2012, 01:13 PM
Lift kits may cause other problems.
Look under the car for any obvious problems such as the exhaust pipe hanging down.
Load the car down with passengers and determine if the rear is now sagging due to weak strut springs.
Old 03-02-2012, 04:43 PM
ac2011's Avatar
i have a 93 with the same problem goings into dipped drive ways.
Old 04-04-2012, 06:28 PM
allcam's Avatar
When I had a 97 it had the same problem. It would sag and bottom out very easily. I would suggest taking a look to make sure there is nothing unusual hanging underneath the car.
If everything looks fine, I'd replace the shocks/springs.
rigz
03-18-2014 09:52 AM
slakhani0188
07-23-2012 08:36 PM
mnieves79
05-16-2009 11:17 AM
Trojan
05-10-2008 10:58 AM
lilnuke
01-18-2007 11:38 PM
Quick Reply: 98 Camry low to the ground
