2002 Camry - 2003 Lexus Wheel Fitment
Old 11-27-2016, 10:03 AM
bizzy's Avatar
Question 2002 Camry - 2003 Lexus Wheel Fitment
I have a 2002 Camry with the 15 inch steel wheels and worn out tires. I found a set of 2003 Lexus GS300 sport wheels with almost new tires an hour or so from my house. The tires are 225/55/R16. I did the tire/rim calculator and see that the fit is close. My biggest fear is that the back tires will rub- There isn't much clearance there. I have no way of test fitting them before I buy them. Is there anybody here that can tell me if these wheels will fit or not before I spend hundreds of dollars and 4 hrs of my time? Thank you in advance!
Old 11-27-2016, 01:10 PM
Try asking at Toyotanation.com which covers both Camry and Lexus.
The biggest change appears to be decreased strut/rim clearance due to rim offset differences. This may require a wheel spacer.
See link below:
Online Wheel and Tyre Fitment Calculator. Offset, Tyre Stretch and Speedo Error | Will They Fit
Old 11-27-2016, 05:29 PM
bizzy's Avatar
Thank you for your advice!
Lowstepside
06-15-2016 01:47 AM
Bad324
08-18-2015 11:15 PM
FLmedic79
01-14-2013 09:54 AM
4doorSupra
06-07-2010 12:36 PM
9secGTPeatsTOYOTAS
07-08-2008 12:18 PM
Quick Reply: 2002 Camry - 2003 Lexus Wheel Fitment
