Go Back   Camry Forums - Toyota Camry Enthusiast Forum > Your Ride > Suspension, Brakes, Tires & Wheels
Sign in using an external account
Register Forgot Password?
Search
submit to reddit
LinkBack Thread Tools Search this Thread
Old 06-18-2008, 10:55 AM
E_S E_S is offline
Default 1989 Camry, front wheel bearing
I need to replace the left front wheel bearing on my '89 Camry. I know how to remove the wheel bearing carrier (AKA steering knuckle) and that I need a hydraulic press, but the new bearing had a design I've never seen before. The sealing rings were separate from the bearing. Is there anything special I should be aware of? The Haynes manual just said "leave this to a professional mechanic", which is my last resort.. I've done dozens of wheel bearing on VWs and Audis before, but never on a Camry.
This ad is not displayed to registered members.
Register your free account today and become a member on Camryforums!
__________________
'89 Camry V6 GXi
Old 06-18-2008, 02:29 PM
Default RE: 1989 Camry, front wheel bearing
For year 1990 this is how it's done. Should be the same or close enough.
Remove knuckle and ball joint.
Remove inner dust cover, inner bearing seal and large snap ring.
Turn hub over. Remove the three bolts holding the outer dust shield plate on.
Toyota uses a puller to remove the hub but a press will work.
Once hub is off, remove outer seal.
Remove old bearing race (may be able to drive out). Press in new bearing.
Install outer seal and bolt on dust cover.
Press in hub.
Install snap ring, inner seal and dust shield.
__________________
Joey P
Old 06-18-2008, 06:10 PM
E_S E_S is offline
Thanks a lot, I'll "attack" the problem in the weekend and then tell how it went..
__________________
'89 Camry V6 GXi
Old 06-20-2008, 02:13 PM
E_S E_S is offline
I'm finished! The previous owner had been driving for a long time with a bad wheel bearing (I just bought it, have not been driving it more than around 100 miles), so it turned out the hub itself was worn down. (horrible noise from the remains of the bearing) After checking with the dealer that the hub & knuckle had the same part number on 4-cyl and V6, I went to the junkyard and pulled a complete unit from a 4-cyl car. I was lucky, as the bearing looked fairly new, so I decided to just put in some new grease and install it. Turned out just fine - now I can start driving the car.
__________________
'89 Camry V6 GXi
submit to reddit
Tags
1989, 89, bearing, bearings, brakes, camry, forums, front, hub, install, left, loose, press, put, toyota, wheel
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
