1995 camry strut removal - Camry Forums - Toyota Camry Forum
Thread Tools Search this Thread
Old 02-04-2007, 03:55 AM
Default 1995 camry strut removal
Has anyone in hereremoved the rear struts??? its a 4 door sedan, i just got some GR2 for it and i can't seem to be able to remove those arm rest next to the rear seats [:@] any tips??? i thought they were held by clips, but i'm begining to doubt it. thanx ahead for any suggestions.
Old 02-07-2007, 10:14 AM
Default RE: 1995 camry strut removal
I did all the struts a few months ago on my 93 sedan. If I remember correctly, there is a bolt on the bottom which you can get to by lifting up the bottom corner. There is a hook up higher that disconnects by lifting up on the cushon after you remove the bottom bolt. I learned the hard way by busting off the first hook. Then on the second side, the bolt at the bottom broke off. You may want to soak it with some penetrating oil first. If you haven't flipped the seat bottom up yet, that will also help.
Old 02-07-2007, 12:20 PM
http://www.turboninjas.com/camry/
one of those manuals will probably help you out.
www.toyotanation.com is another forum you may want to join.
Old 02-08-2007, 05:30 PM
Just like unsub said, there is a large bolt (17mm I believe) at the bottom that holds the armrest in place. And be careful of the hook! A Haynes manual has a nice picture of the whole thing if you need a good visual reference, which you should have anyway if you're replacing your struts.
Don't forget to get an alignment when you're done, you will need it.
Thread Thread Starter Forum Replies Last Post
Rear strut removal 97 Camry LE 4cyl drjpb General Tech 1 05-14-2010 08:02 AM
07 Camry Strut and Strut mount Problems turtle02909 Suspension, Brakes, Tires & Wheels 1 01-25-2010 09:21 PM
1995 Camry distributor removal mcbriggs DIY - Do It Yourself 0 06-18-2009 05:38 PM
Changing strut mounts 98 Camry LE 4 cyl. jh818 New Member Area 1 01-04-2007 08:33 PM
APEXi Custom intake for 4 cyl Camry with free strut tower bar $100.00 cpark PRIVATE For Sale / Trade Classifieds 1 08-23-2006 09:18 PM
Tags
1995, 95, camry, changing, cost, installing, picture, quick, rear, removal, replace, replacing, show, strut, struts, toyota
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
