1995 V6 LE suspension/ wheel upgrades?
Old 12-07-2013, 12:15 AM
rover215's Avatar
Default 1995 V6 LE suspension/ wheel upgrades?
I bought a nice V6 LE wagon last week froma one (family) owner. They kept all the service records (and window sticker) and it's clearly been well taken care of. Runs great, no bad noises, no smoke.
I only want to do some +1 upgrades to the suspension and wheels (and maybe brakes). It rides okay, but it's all stock so it's a softy. I'd like to replace the 15" alloys with a set of 16" with a stiffer suspension. Not looking for STIFF, just firmer than stock. I like the stock brakes so unless there's a good, cheap upgrade, they'll stay stock.
Any ideas?
Old 12-07-2013, 02:07 AM
I'm not sure what is out there for the 95 Camry V6 but I'm sure you can find somethings. Since you have complete records for the car, when was the last time the struts were changed? I bet there are some spring kits out there but they might lower the car about an inch in all four corners. Check the tie rods for play because you will feel that in the steering wheel for sure and can cause vibration. If everything checks out then I would look into beefier sway bars for front and rear. Again, I am not sure what is out there for your particular model but I bet there is something out there.
fibrewizard
01-15-2020 01:27 PM
rs3
10-30-2014 03:54 PM
moh.vze.com
12-05-2012 09:16 PM
myminxscamry
07-01-2007 11:10 AM
milla95
06-06-2006 08:32 AM
Quick Reply: 1995 V6 LE suspension/ wheel upgrades?
