1997 Camry Makes a Whoosh Sound While Braking
Old 09-09-2015, 12:32 AM
jayinc11's Avatar
Default 1997 Camry Makes a Whoosh Sound While Braking
Whenever i am braking and especially if I am in a left turning direction I hear this whoosh sound. The disk feels like it has groves. Are my brakes out?
Old 09-09-2015, 03:08 AM
dirty hands's Avatar
have the rotors and discs checked without delay
if they are grooved or pads worn out ..cant keep driving it like that
when braking ....is the pedal hard or does it drop away
a woosh might also be a front gas strut leaking or vacuum leak
Old 09-10-2015, 11:16 PM
I second Dirty Hands recommendation.
Old 09-12-2015, 06:21 AM
jayinc11's Avatar
I jacked up the car and yes the pads are low. I need new brakes.
The current pads were installed around 2008/9. Is this a reasonable time frame for pads life?
I have heard that there are lifetime brakes pads or very long life extended pads. Is this true or a gimmick? Can you shade some light on this?
Old 09-16-2015, 12:14 AM
The time frame from when they were installed seems pretty good. It all really depends on miles and how you drive the car.
I wouldn't waste money on extended life brake pads. I would buy quality brake pads. The long life pads tend have a harder compound. The harder compound can reduce stopping efficiency and generate excess heat that can warp rotors.
flpalla
10-06-2010 09:48 AM
derbay2002
04-17-2010 09:59 AM
rakeshcamry96forum
02-25-2010 01:32 PM
the.stick
01-16-2010 10:48 AM
paperpoopoo
05-12-2009 04:33 PM
Quick Reply: 1997 Camry Makes a Whoosh Sound While Braking
