Browse all: Wheels and Tires
- Toyota Camry 4th, 5th, and 6th gen Tire Modifications and Size Calculator
Important information to help you understand your Camry
2003 Camry 4th set tires & only 86k miles! Anybody else with this problem???
#12
RE: 2003 Camry 4th set tires & only 86k miles! Anybody else with this problem???
Its your alingment, im telling you right off off the back, i may not know what may have the caused the problem, but try running, 35 lbs of pressure, sounds like eyou have a positive camber problem, where are you located? i may beable to help you fix it? Do you have alot of potholes? that may just be the case and may have bent up your suspension, the garages never want to admit their faults,
post some pics of the tires and i could help you from there
#14
i ve got an 06 with 17s also with 76k on them on my second set of dunlaps and the first set was the factory turanza el42 that gave out at like 40k i think so i think it might be your car
#16
My car is dealer serviced every 3000 miles, they did alignments as required, the tires are not under-inflated. 35 PSI is NOT the manufacturer's spec. I was complaining I thought it was the Dunlops, what else are they selling, but if it's the car, then Toyota owes me a tire discount, not Dunlop.
#17
Hey ginakins77, I think it is a car problem. Happening to too many for it not to be. I have and 02 Camry SE and an 2012 XLE hybrid. The XLE has only 30k on the tires and front are shot. Has been serviced by dealer and rotated regularly. The 02 went through tires ever 25K or so. So, this will be my last Toyota. When you look around this has been a problem for a long time and Toyota has not addressed the issue. Think I will go back to Honda or Nissan.
photo2u
04-02-2012 12:48 AM
albert101
01-17-2008 10:32 AM
hoangkb
07-24-2007 10:08 PM
