Browse all: Brake Guides
- Toyota Camry 4th gen How to Replace Brake Pads, Calipers, and Rotors
Step by step instructions for do-it-yourself repairs
2010 Camry Brake Pedal Issue
Just had local shop (not dealer) flush and replace all break fluid. Gravity bleed. Now the brakes seem to work OK except the pedal is very soft and will go all the way to the floor. Scarey feeling. They will not pump-up. Bleeding does not help and no air comes out. I see comments about bleeding ABS module and/or master cylinder. Could these be the issue or something else? I'd appreciate any and all suggestions. Thanks.
Suggest starting by taking the car back and asking the shop to correct the problem. If the pedal goes to the floor, the shop should be concerned from a liability stand point and want to correct the problem.
Otherwise your options are to bleed the master cylinder, then ABS module. The module may require a electrical tester to activate it and move the fluid out the brake bleeding fittings.
dividingbyzero
05-08-2015 09:10 AM
CamryLastFoureverNever
03-16-2015 07:57 PM
turtle02909
05-27-2009 08:16 PM
