2014 alloy wheels on a 2010 Camry
I recently purchased a set of alloy wheels from a 2014 Camry to put on my non-alloy wheeled 2010 Camry. From my research it appears they should fit, except the wheels are bigger (17" compared to the original 16"). All other specs are inline with the old wheels (Number of Bolts, Bolt Pattern, Offset). I plan on buying new tires as well, but I'm still worried the actual wheel won't fit on the car or I overlooked something else (tire pressure sensor won't fit from the old wheels, etc). If anyone has experience with this let me know if you see any problems with this set-up.
Thank you.
Thank you.
17 inch rims where available as OEM for the 2010.
The tire pressure sensor mounts inside the stem hole in rim, should work OK. If concerned take replacement rim to whoever will be mounting the tires and ask.
Bigasshammm
07-04-2010 06:11 PM
illmatic
03-22-2008 01:58 AM
