'89 Camry Clicking Noise When Turning (fwd - V6)
Old 06-25-2008, 09:06 PM
axlman's Avatar
Default '89 Camry Clicking Noise When Turning (fwd - V6)
For awhile now, I've been hearing a clicking/clanking noise coming from the front end when I do a hard turn to the right. This happens usally when I'm parked and have to turn my steering wheel all the way to the right when backing out or pulling foward. My mechanic say's that my CV boots don't look cracked or anything but they are not too sure if it's the Axels or not yet.
I did a google search last weekend and found some people stating that it's the boots or axels. Has anyone else had this problem? if so, what was the issue and the fix?
If my mechanic say's that the boots are good and the axels are ok, should I replace them anyway just in case? [/align]
Old 06-26-2008, 12:24 PM
Default RE: '89 Camry Clicking Noise When Turning (fwd - V6)
Yes, clicking can be a sign of worn joints, and the boot can still be OK.
Try making left and right hand turns at slow speeds and listen for clicking.
Typically the bad joint is on the opposite side of the direction of turn.
Old 07-02-2012, 05:48 PM
allcam's Avatar
It could be the axle or CV joint. The boots can be fine, but that doesn't mean the internals are.
chaiyang7
03-23-2012 09:02 PM
restore
01-04-2011 10:27 AM
flpalla
10-06-2010 09:48 AM
red73mustang
03-26-2008 07:42 AM
ttcmy17
02-21-2008 07:33 PM
Quick Reply: '89 Camry Clicking Noise When Turning (fwd - V6)
