94 camry rear suspension - little help
Ok, so usually on the highway or about45mph+I getalot ofshakingand noise from the back of the car.Well I finallyjacked it up to check it outand the strut rods and arms seem to be good, but the stabilizer bar seemslike it hastoo much play or movementin it. The bar itself is good no cracks or rust, but I suspect I need new bushings? So after all thatI guess what im trying to ask isif the stabilizer bar issuppose to move at all? Any help is appreciated.
RE: 94 camry rear suspension - little help
Other then normal suspension up and down travel there should be no side play in the stabilizer bar bushings. Same for strut rod. The bushings can wear out.
Also check for play in the sway bar bushings and end links.
The stabilizer and sway bar bushing should be available plus end links as aftermarket parts.
The strut rod bushing appears to be a Toyota only part and sold only with the bar as a complete unit.
italianjeremy
05-14-2007 09:37 AM
