97 camry rear shocks
Old 07-06-2013, 04:31 PM
Hung Nguyen's Avatar
Default 97 camry rear shocks
I just bought new kyb shocks and replaced both rear, but I still feel harshness when driving over small cracks or bumps on the road which shouldn't be the case. I also hear loud clunking noise after I run over a bump or crack on the road from the rear trunk area. Does anyone have any ideas what the problem is?
Old 09-10-2013, 07:44 PM
Mark DiSilvestro's Avatar
Don't know what make the factory shocks are on these, but KYBs have a reputation of being too stiff for some applicaions.
My car is a '96 LE
Because I carry a fair amount of weight and recently added a custom light-duty trailer hitch, I decided to replace my rear springs & struts.
My struts were completely blown out anyway.
I found a good set of rear Camry wagon struts & springs in my local salvage-yard for $65.
(New ones would've been $350 - $450!)
Ride is certainly stiffer but not uncomfortable, and there's virtually no bottoming at road-dips and driveways now.
Common cause of rear suspension noises are worn rear stabilizer-bar links and bushings.
When I got this car two years ago, the rear stabilizer bushings had become enlarged over the years. My quick-fix was to remove the 'U' brackets & rubber bushings and wrap the contact area of the stabilizer-bar with a few layers of electrical-tape.
Then before reinstalling, I lubed the inside of the rubber bushings with a bit of silicone to prevent binding and squeaks. It's lasted two years on mine.
No quick-fix for the links. If yours are loose & noisy, you'll need new ones.
Happy Motoring, Mark
james007
01-02-2012 03:41 PM
hardyrxp
04-04-2010 01:08 AM
hardyrxp
03-31-2010 02:19 AM
madquake
05-28-2008 07:24 PM
vin888
07-25-2007 12:13 AM
Quick Reply: 97 camry rear shocks
