clunking noise in front brakes
Just changed front disk brakes on 97 camry during test drive i notices a clunking noise in front brake area when moving in reverse when I engaged brakes. it only happend once while in reverse before going forward. While going forward and engageing brakes I heard the clunking sound again but only once. Didnt happen again while going forward this time.Then put car in reverse and breaked again and heard the clunking again but only once while in reverse this time. Put car in forward and hit breaks and heare clunking sound again but only once while in reverse this time. This cycle continues. Dont know what I could have done to the breaks to cause this since changing brakes is pretty simple
When the cars moves backward and the brakes are applied, the brakes pads may be shifting backward in the torque plate slots they are installed in.
Make sure all the original clips, shims, etc are installed if possible. Some aftermarket pads don't allow use of this items.
If this is the problem, your only issue is noise.
Just got the car bout 6 wks ago, 2012 36500 kmiles. Don't know anything bout the brakes.
Checked it in reverse last night, did it a lot. Was gonna have brake check look at it today, didn't do it this morn.. How long do the brakes usually last on a camry. Just got out of nissan & no brake problems til 90k.
Ok just got back from brake ck. since the noise came back at lunch. He said do everything, I said just clean & adjust since the hardware was dirty with build up. Plenty of pad left, just a little pitted. So far so good. Let u know if it comes back. Out less $19.
It's back. Had a friend listen to see which tire it was since brake ck only addressed the back. It is the front passenger wheel. My friend thanks the pens are riding on the calipers. He suggested DW-40 on the pens. Any thoughts?
I wouldn't bother with WD 40 on this particular region. They make brake lube and it can be found at your local parts store. Usually when you get new brake pads there is a small packet of lube in the box. You then lube where the pads contact the caliper, usually on new shims.
