eibach springs help
RE: eibach springs help
Depends on what you're looking to get out of your car. From what someone on here told me a few days ago Eibach's are basically what TRD sells for the camry. Here's the link to my thread, if it helps at all.
Eibachs on 97 Camry
Eibachs on 97 Camry
thanks a lot for your help man. Now i have a question of whether or not to get the full coil over the just the eibach springs. if the the full coilover installation price is really expensive i might not get it. i am also wondering if i should get strut bars, sway bars, the coilover, or the springs. I want the best suspension part i can get without anything going wrong later when driving my car.
I think if you are going to spend the $$$ for your suspension, I would go with Bilstien or Tien full coilovers and for the swaybars are everything else I would go with Whitline. Whiteline Is a perfect blend of track and street (and I believe you can adjust it to go more one way than the other), Good luck! (those coilovers will run you $1500-$2000)
Now, I know the TRD springs are Eibachs...I looked around and it seems that if you buy Eibach, you spend about $100 more...I have an '08 Camry SE...and I think the SE model has an upgraded suspension...anyone can explain to me or correct me what was the upgrade? I'm guessing the car was dropped a little, and has a rear sway bar. My friend pointed it out and it was this skinny rod thing...I don't know if he's right. I went to a shop and they recommended a TEIN coilover kit. VERY pricey. But I did see a Camry with a coilover kit, (I forgot what brand) and he said it cost him $1050. It was slammed with stock rims...very sweet.
In any case, does going a full coil-over setup would help me regarding this matter? Thanks!
__________________________________
Powered by Autopartswarehouse
mikeynavy1
07-31-2011 10:21 PM
