Rear Disk Brakes
Rear Disk Brakes
I plan on re-padding the rear disk brakes on my 2002 Camry. I used to be a ASE mechanic so I am no stranger to brakes jobs. My question is, to push the pistons back into the caliper, do I have to rotate them and in which direction? Your help would be greatly apprecieated, Tbone.
The car (a Camry) has a separate shoe type parking brake system.
The rotor is a combo disk and drum design.
You may need to back off the shoes to get the rotor off. The pistons have no other special powers beside pushing on the pads.
This car does have rear disk brakes and most of the ones I have been associated with, you have to turn the rotor while you are pressing the pistions back into the caliper because of the parking brake. But I guess since this car has seperate shoes for that purpose. I don't have to worry about that. I do not plan on removing the rotors to have them turned. I am just replacing the pads. Thanks again, Tbone.
eyeblazin
05-13-2013 12:36 PM
KenL
04-07-2008 08:50 PM
