Browse all: Steering & Suspension Guides
- Toyota Camry 2002-2006: How to Replace Rear Wheel Bearings
Rear Wheel Hub Assembly Question
Hello All:
I have a 2003 Camry XLE 4 cyl with ABS. I'm looking to replace the drivers side rear wheel hub assembly because the bearing is squealing. In looking for one on the internet, I see one part model has a gear coming off the backside and they call it a sensor ring. The other has a plug in receptacle for the ABS sensor. Both state they are for cars with ABS. Which one do I need? I'm thinking of buying a timken brand part because I'm familiar with their quality. Is this correct? Which parts house do you recommend?
Thank You: Michael
Thank You: Michael
Michael,
I am having the same problem with my wife's '05. There seems to be a roar at speed. I jacked the car and put it on stands. I took the rear wheels off and slightly opened the caliper so the pads would not rub the rotor. I reinstalled the wheel and spun it. I could hear the bearing noise in the right rear.
On my '05 (and I think on yours too) the ABS sensor is an itegral part of the unit.
Go here for repair DIY:
| Repair Guides | Rear Suspension | Wheel Bearings | AutoZone.com
Now, to the bad part: Toyota dealer priced a hub assembly at $377.02. Autozone has a Duralast unit (Chinese) for $128.99, one year warranty.
Here's the KICKER: for my '05 there are two Timken parts listed - one for the driver's side ($214.99) and one for the passenger side ($148.99) I had the counter technician double-checkit.
In any event, go with the Timken - three year warranty.
This is not a hard job. Basically four bolts. Do a Google search for "replacing Toyota rear wheel bearing" and go from there.
Hope this helps, Gary
Thanks Gary:
Gary:
I am finding the same thing here, that the drivers side is about $50.00 more than the passenger side. I will check out your "how to" links and try the repair this weekend.
Thanks: Michael
Thanks: Michael
mjdejan23
02-05-2015 11:41 AM
eyeblazin
05-13-2013 12:36 PM
