Steering stiff and sticking
#14
Hey Guys,
Just wanted to say thanks for the info on the steering problem. I was having the same problems on my 97 Camry. I tried several types of spray lubes, 10w-40, white lithium, pb blaster all with little or no help. I was starting to think I would have to replace the joint until I went on a mission to find the tri-flow with Teflon. Since none of the local parts stores carry tri-flow I went to the internet for help and found out that many bicycle enthusiasts swear by this as a great chain and sprocket lube. So I went to my local bike shop and sure enough they had it for sale. But at $10 for a small can I took a pass. I then went to Home Depot and found a spray lubricant with teflon. Can't remember what the name was just remember that it had teflon and it was only about $5 for a large can. I tried it out by soaking the joint and then turning the wheel and spraying the joint again from the other side. This worked great and has been good for about a month now. I think that the teflon must be the key ingredient to making the joint loosen up and stay that way.
Good luck to all others.
#15
Still going strong
I just checked this thread and realized it's been over 3 and a half years since I had the steering problem.
Steering is still working fine, and I probably haven't sprayed the u-joint in over a year!
I salute the lubricating power of TEFLON !!!
#16
When driving this first day everything ran very smooth and very light. After I took it to get State Inspections and Emissions, for the last couple days, the car has been feeling somewhat heavier. I ran it by the shop I went to and they test drove it and said it was fine. The steering seams to be a bit heavy no when I turn. The wheel does set back smoothly at all. The car doesn't seem to run as "light anymore" The wheel feels very heavy/dragging at times when steering from right to left.
I heard that spraying Tri-Flow lube with teflon on the Universal (U-Joint)/steering column will work wonders in making it smoother.
How do I locate the Universal joint for spray application in my camry? I'm not so much of a car part savy guy
Thank you! Any help appreciated!
#17
Teflon works
After reading this for same issue I noticed on my 04 Camry I took it to dealer and asked to lube with Teflon. And they sprayed but not sure if it was Teflon or something else as it did not help. I bought it and gave it a try before taking it back for repair and this thing works really well and quickly. Glad to have seen this. Thanks
#18
I met same problem, how to locate the Universal joint?
My Camry run into same problem. Checked Power Steering liquid , it is OK. Belt and tires are fine.
Just wonder:
#1 How to verify if the pump working (for Power Steering liquid)
#2 How to locate the universal joint? can I touch it from Cockpit, or, do I need to open engineer lid to touch it?
Advice would be appreciated!
Just wonder:
#19
If the pumped failed, the steering would be very hard.
The link below provides information for 2003-2006 Camry and can help you find the joint on your car.
http://file.seekpart.com/keywordpdf/...1322781266.pdf
#20
Thanks for everyone for share the experience
I met the same situation and got it fixed. I would like to express sincere appreciation for everyone to share the experience.
I use a lubrication with Teflon in Homedepot, which works. forgot the brand name, but it can work under the temperature of minus 13, which make sense in the northern area.
