Camry LE 2005 Washer Fluid Reservoir Leak
Old 06-02-2012, 10:07 PM
nowinnc's Avatar
Default Camry LE 2005 Washer Fluid Reservoir Leak
Today I was just topped off my Camry's Washer Fluid Reservoir which was down by an inch or two. After topping the fluid I think put little bit pressure from my fist to close the lid. It looks like I might have ruptured the tank completely. Fluid pours off immediately. I started the car and checked if my wiper motor works or not, fortunately it works and it sprays on the windshield and vipers works as usual. So how do I fix the leak. It is not a minor leak, it pours off fast. Do I have to buy a new tank or can I just fix the tank with a washer or something like that. How difficult is it to replace the tank. It looks like the reservoir pump works fine. I don't see any visible cracks in the neck of the reservoir. I tried to look underneath the tank but it completely shielded and the shield is bolted to the bumper.
Any idea or advice will be appreciated.
TIA
Old 06-03-2012, 08:35 AM
boricua's Avatar
remove fender mud liner to get a better look at it ,most of the times the leak is from the washer pump seal or the pump bottom , removing the liner is a easy work a few bolts and push on pins . if bottle is crack repair it is not recommended to the temperature changes .
Old 06-03-2012, 11:31 AM
nowinnc's Avatar
I removed the mud liner and peeked in and it looks like the reservoir is full more than a gal and I don't see any leak. My wiper works fine and sprays on my wind shield perfectly fine. What actually happened is I poured too much until the brim of the long neck of the tank very close to the lid and what ever excess in the neck part of the tank spilled out. No I problem. I will make sure that I don't fill too much.
Thanks boricau for your quick reply.
artaman
01-08-2011 10:58 AM
Wes
01-11-2010 07:16 PM
Player
11-17-2008 05:45 PM
cjwebber
08-24-2008 12:14 AM
septicman
03-06-2008 08:51 AM
Quick Reply: Camry LE 2005 Washer Fluid Reservoir Leak
