Camry won't start after filling with gas
My 2004 camry has issues when I fill with gas at the gas station. It will turn over but not start. If I can get it to turn over runs very bad, I basically have to feather the gas to keep it going.
After a while will run fine. Any ideas?
toyomoho has mentioned bad fuel from a filling station
this car no start .... has happened straight after filling the tank
possible symptoms of bad gas . are something trapped in the cars petrol filter stopping fuel flow
could be
fine particles of rust from the ground tanks .. water from condensation.... or stale fuel.
if the filter checks out ...... then there will be another cause . and will need investigating
could be
Camry hard to start after refueling?
If your Camry is hard to start after refueling every time and starts normally all other times. Then first try this. Once you finish fueling, make sure the gas cap is tight. Turn the A/C switch to max cool. And the fan switch to max also. Then as you are cranking the vehicle slowly press the accelerator gradually to the floor. Then if it catches and starts but you have to continually pressing the accelerator to the floor to keep it on. Then it is one thing. It is your fuel pump located in the tank. Replace the whole assembly or most importantly the pump inside the assembly. But make sure it’s the exact pump for your vehicle. When it happened to me I had a Chk-Eng light too. Once the Assembly was replaced the light went out and car ran normal. Good luck!
