Ecu for 2003 Toyota Camry
Old 08-13-2015, 08:15 PM
Kacgraphics's Avatar
Default Ecu for 2003 Toyota Camry
I brought my Camry to the shop due to the locks not working properly, they said I need an electrical control unit, will that take care of my problem? And what is an ecu and is it expensive and does it take a long time to fix? Thank you
Old 08-13-2015, 08:55 PM
Do any of the locks work?
The ECU is plugin part. Shop Epay or auto salvage yard for a used part.
Old 08-14-2015, 07:57 AM
Default Ecu for 2003 Camry
The driver side only. I have a warranty on this car and was wondering where the part is on my car and is it expensive to fix, just in case my warranty doesn't cover it.
Old 08-14-2015, 11:59 PM
Problem appears to be the ECU. DIY should be reasonable cost. Shop might be $400+
Old 08-15-2015, 12:00 AM
The ECU is the brains of the car. If you have a warranty and it doesn't cover the ECU/electronics, etc. then your warranty stinks. The actual part is not to hard to get a hold of but it typically requires the dealer to do the programming (matchmaking).
The time to replace the part is not long, to program takes maybe an hour or two.
If your warranty tries to deny this claim, I would fight them.
Old 08-15-2015, 01:20 PM
Default 2003 camry
I want to thank you very much for replying to my questions. You have have really helped.
Old 08-16-2015, 10:59 AM
The car has more then one ECU. The issue seems to be the Body ECU that in part controls the door locks.
amrulloh1004
11-16-2014 11:34 PM
Monguse
10-06-2007 12:54 AM
99champcam
08-15-2007 11:46 AM
ExpressTrain
02-20-2007 05:29 AM
BearChest
08-18-2006 03:49 PM
Quick Reply: Ecu for 2003 Toyota Camry
