Toyota Camry 1997-2001: How to Remove Rear Bumper
Was your Camry in a small fender bender recently? Replacing it is not as expensive as it seems; use this article to save some money on your repair.
This article applies to the Toyota Camry (1997-2001).
Are you retrofitting some new tail lights? Perhaps you need to replace the bumper due to a small fender bender? Whatever the reason, your Camry bumper is very easy to remove and replace. All you need is a few hand tools, some motivation to save a hundred bucks and a few hours of your time. Use these following instructions to remove your rear bumper.
Materials Needed
- Screwdriver
- 10mm socket
- Clip remover
Step 1 – Open the trunk and remove its panels
First pop open the trunk and pry off both panels by hand. At this point you should notice the nuts which are located behind each cover.
Step 2 – Remove all the bumper cover clips and hardware
- Remove the bumper cover clips, some of which may require a Phillips screwdriver to pry off.
- Use a 10mm socket to remove the bolts and nuts located around the bumper cover (refer to Figure 2).
- Grab the bumper cover and slowly pull it back, make sure it is not stuck on anything.
- Remove the bumper cover.
Step 3 – Replace the bumper cover
If you are replacing a bumper cover that had initially been damaged, make sure to inspect the support and ensure it is in good shape. After affirming that everything on the support is okay, proceed with the installation process.
- Align the bumper cover with the vehicle.
- Lock the bumper cover corners in first with the mounting clips.
- Tighten each nut and bolt around the bumper cover to 43 in-lbs.
- Adjust the inside of the trunk panels and clip them back into place.
Pro Tip
If you were replacing the bumper, make sure you had the new unit paint matched. Otherwise the new shade of paint on the bumper can throw the entire flow of the car off!
Related Discussion
- Remove Rear Bumper - Camryforums.com
