Toyota Camry 1997-2001: How to Replace Oil Pump and Seals
If you have a serious oil leakage problem, especially when idling, you likely need a new oil pump.
This article applies to the 4th Generation Toyota Camry (1997-2001).
Oil leaks are no fun at all, either to diagnose or to repair. But no matter how small, they should never be overlooked. Some oil leaks can be innocuous enough, either a bad oil filter gasket or even an oil pan gasket. In either case, you may not have much oil leakage at all, but just enough to be annoying. These are simple repairs that you can do on your own in just a few minutes to a couple of hours at worst. If you have a significant oil leak, a really major one, especially one that really shows itself when you start your Camry, it could be a bad oil pump. This is not a cheap repair, but it is not one that you have to take to a professional to fix. You can change your oil pump without too much trouble with a little mechanical know-how, and this will save you a ton of money from having the pro do the job. Just go slow, take your time, and follow this guide to be back on the road with a sense of accomplishment that you did a pretty major repair successfully on your own.
Materials Needed
- Ratchet and socket set of various lengths
- Hydraulic floor jack
- Jack stands
- Breaker bar
- Putty knife or scraper
The most common issue with an oil pump leak on these Camrys is a seal leakage. The pumps themselves are pretty much bullet proof, and leaks are almost always caused by the inner or the outer seal failure rather than any mechanical failure. This article will show you how to replace the seals rather than replacing the entire pump assembly, which will save you a ton of money.
Step 1 – Jack up your car
- Use a hydraulic floor jack to lift the front end and place on jack stands.
- Chock the rear wheels.
- Remove the passenger's side tire.
Pro Tip
Always use jack stands when working under your car. Never use a floor jack only, because it can slip or suddenly collapse causing serious injuries.
Step 2 – Disconnect battery
- Remove the negative (black) battery terminal.
- Never work in the engine compartment without disconnecting the battery first.
Step 3 – Remove belts
- Remove the alternator, compressor, and main drive belts.
- Remove the power steering belt.
(Related Article: How to Replace Serpentine Belt - CamryForums.com)
Step 4 – Remove timing belt cover and timing belt
- Once the other belts are removed, the four bolts for the timing belt cover will be exposed.
- Remove the four bolts and pull off the timing belt cover. Set aside.
- Remove the crank bolt and the crank pulley (make sure you mark the TDC on the crank pulley gear to match back up when replacing).
- Once the crank pulley is off, it will expose the 10mm lower timing cover bolts. Remove those bolts.
- Pull off the lower timing belt cover.
- Remove timing belt.
(Related Article: How to Replace Timing Belt - CamryForums.com)
Step 5 – Remove oil pump housing
- Use a short socket on the six bolts that mount the oil pump housing and remove the bolts.
- The six bolts are of different lengths, so make sure you note their proper locations on the housing.
- Pull off the oil pump housing.
Step 6 – Inspect and replace the oil pump seals
- With the pump housing off, there are two main seals that go bad.
- The inner seal is a small O-ring type of seal. This is a little trickier to remove and replace, but isn't too difficult.
- The outer seal is quite a bit bigger, but should pop in cleanly and easily once the old one is removed.
- Use a plastic putty knife or scraper to make sure you get all the old seal remnants out of the seat.
- Re-seat the new seals and the housing can be put back in place.
Step 7 – Button your car back up
- Replace the oil pump housing bolts and torque them down to specification.
- When replacing the crank pulley, make sure that the TDC mark on the gears match up or you will have a timing problem.
- The cam shaft wasn't messed with, so the marks should line up appropriately already.
- If you are anywhere near the recommended mileage for the timing belt replacement, you might as well put a new one on now since you are already in here. The water pump is normally changed out at the same time, so you can tackle that as well or wait on that until the time comes.
- Replace the timing belt.
- Replace the lower timing cover.
- Replace the upper timing cover.
- Replace the other belts.
Step 8 – Start the car and check for leaks
- Re-connect the negative terminal.
- Start the car, and check for any leaks from the oil pump.
- Check the oil pressure indicator light on the dash.
- Turn the wheels all the way to the right and then to the left to watch for the oil pressure light.
- If everything is looking good, shut the car off.
- Replace the tire and drop the car.
- Take it for a test drive with plenty of hard turns in both directions, watching for any warning lights.
- Park the car to check for any leaks after it has been sufficiently warmed up and driven a while.
Related Discussions and Videos
- Oil Pump Leak, What Seals? - CamryForums.com
- 98 Camry Crank Shaft Gear Removal - CamryForums.com
- Oil Pump Seal - CamryForums.com
- 1998 Camry Major Oil Leak - YouTube.com
- Toyota Camry Large Oil Leak - YouTube.com
