Toyota Camry 1997-2001: Owner's Manuals
Your owner's manual holds important maintenance information you'll need to know about your fourth generation Toyota Camry.
By Charlie Gaston - July 22, 2015
This article applies to the Toyota Camry (1997-2001).
The cost to replace a hard copy factory service manual could run you between $300 and $400, easily. If you're like most, however, this is a lot of money to shell out at one time. That's why we've compiled this no non-sense guide to your fourth generation Toyota Camry and its required scheduled maintenance. While we couldn't pack all the information that's included in the original factory service manual for your Camry, our experts have combed over pages and pages of information to provide the most important maintenance suggestions and tips right here for you in this handy electronic guide. It's recommended that you speak to a local Toyota dealer about your vehicle's specific needs before getting started with any maintenance or repair work.
Fourth Generation Camry Service Items
Air Conditioning System
Your factory service manual explains the nuts and bolts of your air conditioning system, along with its required maintenance. The most important things you'll want to know are:
  • ONLY use the correct refrigerant and compressor oil. Failure to do so could result in serious damage to your compressor.
  • As well, have your mechanic check your O-rings and seals regularly for wear and tear.
  • All connecting parts should be securely tightened.
  • If there is a leak in your system, it should be fixed immediately.
  • Your vacuum pump should be in good working order at all times.
Figure 1. Keep your air conditioning system in good working order.
Electrical System
Your electrical system controls many functions in your Camry. To keep your vehicle in good working order, replace broken connectors and blown fuses as they occur. Be sure to check that the fuse amperage rating is correct before installing, however. For a terminal replacement, it's recommended that you seek professional assistance. Finally, check your battery regularly for proper voltage. If your system has a short circuit, a professional mechanic will need to identify its location and resolve the issue using specialized tools; only attempt this repair if you are skilled in wiring. Your audio system, supplemental restraint system and headlight systems all require regular inspections. Replace faulty electrical related parts as needed.
Figure 2. Maintain your Camry's electrical system.
Brake System
Your brake system could spell the difference between you becoming involved in a dangerous collision and avoiding one. Because your brake system involves many working parts, including your parking brake and foot brake, it's recommended that you visit a local Toyota dealership for all brake work; unless you are skilled in working under the hood of a car and/or familiar with complex brake components. Add lubrication (brake fluid) as needed. Your brake pads should be performance-ready at all times. Have your brake pedal and parking pedal checked and adjusted as needed. Finally, bleed the air from your master cylinder if air in the brake lines is suspected. It's important to reiterate that most of the above-mentioned maintenance, repairs and checks should be performed by a certified mechanic.
Figure 3. Your brake system is complex and involves many working parts.
Scheduled Maintenance
Fourth generation Camry models require regular maintenance, and at this point in your car's lifespan that should include replacing your fluids at regular intervals and checking your major systems every 30,000 miles, particularly your transmission and braking systems. If you notice a decrease in gas mileage, clean your fuel system at your next fill-up and check your tires for optimum pressure.
Common Questions
Do fourth generation models require a lot of general maintenance compared to other vehicles?
Fourth generation models require general maintenance, repairs and checks, but not more than other similarly sized family cars and luxury vehicles on the road. Keep your fluids clean and your major systems in good working condition and you can plan on achieving high mileage in this dependable, highly rated model.
Can I purchase a replacement factory service manual through a local dealer?
Yes. You can also purchase a replacement factory service manual direct through the manufacturer. Visit the Toyota website (see link below) or call (800) 782-4356 to speak to a qualified customer service representative.
Is the Haynes Manual any good for fourth generation Camry models?
Many Camry owners rely on the Haynes Manual as a trusted resource for do-it-yourself and professional automotive repairs. However, your best resources will always be your original (or a copy) factory service manual.
Related Sites
