Toyota Camry 2002-2011: Aftermarket Modifications
Aftermarket modifications can help to improve the look and feel of your 5th or 6th generation Toyota Camry. Here's how.
This article applies to the Toyota Camry (2002-2011).
Fifth and sixth generation Toyota Camry models are ideal vehicles for aftermarket modifications. Highly rated, with a proven lifespan of up to 250k to 400k miles, easily, the Toyota Camry is the kind of vehicle you can invest big money into. It's not a show car, but you can make interior and exterior aftermarket modifications to increase the comfort of your daily commute. Let's review the top three picks that rate highest with Camry owners!
For these Toyota Camry models, you have three main options to modify the interior and exterior of your vehicle: fog lights, radio and/or wheels. Each of these modifications can be mounted to your Camry on the cheap. However, it's recommended that you consider brand and quality before committing to your chosen option. Your wallet will thank you later!
Fog Lights
DIY Cost – $10-100
Professional Cost – $150-$400 including parts and labor
Skill Level – Easy/Moderate; Installation kits make set-up easier
This is the most inexpensive way to modify your vehicle. Because you are dealing with a basic sedan, rather than a luxury vehicle, your cost(s) will be reasonable, allowing you to either opt for professional installation or complete the project from the comfort of your own home using a kit. For 5th and 6th gen Camry models, PIAA and Xenon are the go-to brands. If your vehicle is currently under warranty, it's recommended that you check with a local Toyota dealer before beginning the installation process.
Radio
DIY Cost – $50-600+
Professional Cost – $75/hr plus hardware
Skill Level – Easy/Moderate (depending on the set-up); You might need to purchase a wiring harness adapter, among other materials for this project
This is the most effective way to gain improved sound quality in your vehicle. While Boss Audio, JVC and Pioneer are the go-to brands for the Camry, you can also find great deals online for a variety of other brands. If money is a concern, consider dressing up your current original equipment manufacturer (OEM) radio with navigation, satellite radio and a CD player. For the best in sound quality, incorporate an amplifier.
Wheels
DIY Cost – $300+
Professional Cost – $60 (mounting and balancing)
Skill Level – Professional alignment is required to ensure safety and reduce gas mileage while driving
This is the priciest way to bring style or attitude to the exterior of your vehicle. For 5th and 6th gen Camry models, you'll need 15-inch to 16-inch wheels. MSW and Ace are the go-to brands. It's recommended that you leave this project to the professionals. If your stock tires do not fit the alloy wheels you've chosen for your vehicle, a local mechanic will need to detach the pressure monitoring sensors from your OEM tires, and then transfer them over to your new set. If replacement sensors are needed, expect to pay approximately $100-$150 per sensor.
Related Discussions
- Aftermarket Radios - Camryforums.com
- Camry Wheels - Camryforums.com
