Toyota Camry 2007-2011: General Information and Recommended Maintenance Schedule
The Camry is legendary for its reliability, but even the most reliable vehicles need proper care and maintenance. Whether you buy your Camry new or used, it's important to stick to the recommended maintenance schedule to get the most out of your car.
This article applies to the 6th generation Toyota Camry (2007-2011).
You can keep your Camry running like a champ with regular maintenance. Along with oil changes, you'll want to change the oil filter and check the vehicle's tire alignment at specific intervals. If you have a bit of mechanical knowledge, you can do the majority of the basic maintenance services yourself. Keep in mind that maintenance schedules may vary slightly based on your Camry year and model, as well as your driving style and the road conditions. Here is a look at the basic maintenance schedule for a 2010 Toyota Camry with a 4-cylinder engine.
Mileage/Months |
Maintenance |
Inspections |
10,000/12 |
20,000/24 |
30,000/36 |
40,000/48 |
50,000/60 |
60,000/72 |
70,000/84 |
80,000/96 |
90,000/108 |
100,000/120 |
Engine Oil
According to Toyota, Camry's with OW-20 motor oil can go 10,000 miles between changes. While it's OK to use 5W-20 mineral oil, this oil must be replaced every 5,000 miles or six months.
Toyota recommends using full synthetic oil to extend the life of your vehicle. While the manufacturer recommends oil changes every 10,000 miles, modern Camry's equipped with an oil life indicator will let you know when it's time to change the oil in your car. These intervals may be shorter than the recommended mileage, particularly if you drive in harsh conditions or take frequent short trips.
Pro Tip
It's also a good idea to inspect the drive belt, ball joints, exhaust pipe, and transmission fluid as the vehicle ages.
Spark Plugs
Spark plugs should be replaced every 120,000 to 150,000 miles, depending on the vehicle. With the exception of cars classified as a partial zero-emissions vehicle (PZEV) in California, Maine, New York, Vermont, and Massachusetts, which require the spark plugs to be changed at 150,000 miles, all other vehicles should have their spark plugs replaced at 120,000 miles or 144 months.
Tire Rotation
It's important to rotate the tires every 5,000 to 10,000 miles, depending on your driving style and the daily road conditions. You can find specific tire rotation instructions in your owner's manual. Proper tire rotation involves inspecting the tires for damage and uneven wear. And if the tires have too much wear, it may be necessary to replace them all.
Featured Video: General Information and Recommended Maintenance
Related Discussions and Site
- Toyota Owners Manuals - Toyota.com
- 2010 Camry 2.5L I4 Engine oil - CamryForums.com
- Maintenance for Camry with 100,000 Miles - CamryForums.com
