Toyota Camry 2007-2011: How to Replace the Starter
If you're cranking the ignition and nothing happens, you've a problem. Your problem is likely the starter, so let's replace it with a fresh one.
This article applies to the 6th generation Toyota Camry (2007-2011).
If you are having trouble starting your Toyota Camry, a faulty starter could be the cause of the problem. If you've already tested your battery and you have to "whack" your starter to get it to work, now might be the time to go ahead and get it replaced. If your starter has gone bad, you won't get anything when you try to start the car, outside of a clicking noise. If your "idiot lights" (dash lights) are dim when trying to start the car, it rules out the ignition switch. Once you've ruled out these other culprits, it's time to replace that faulty starter.
Materials Needed
- Ratchet
- 14mm and 12mm sockets and extension
Step 1 – Remove starter
The starter sits on top of the engine and is held in place by two bolts, one on each side. The Toyota manual states that the cruise control cable must be removed to remove the starter, but this isn't completely necessary. Remove the air intake and bracket, both of which are held in place by two bolts. Remove the air cleaner housing by removing the three bolts in the bottom of the assembly. Remove the negative (black) as well as positive battery cables and pull the battery out. Remove the 14mm lower bolt and 12mm upper nut holding the starter in place, and disconnect the wiring harnesses from the starter. Pull the old starter out.
Step 2 – Install new starter
Set the new starter in place and install the lower 14mm bolt. Slide the wiring harness over the top bolt, making sure the two metal tabs slide all the way in. Install the top 12mm nut and tighten, being careful to not over-tighten and break the tab. Connect the other wiring harness right below it by pushing it into place until it clicks. Replace the air intake, bracket, and air filter cleaner housing, re-installing and tightening all bolts. Re-install the battery and reconnect the negative as well as positive battery terminals.
Featured Video: How to Replace the Starter
Related Discussions
- Battery or Starter Issue - CamryForums.com
- How to Test Starter Solenoid? - CamryForums.com
- Camry Starter Issues - CamryForums.com
- Starter Problems - CamryForums.com
