1995 Toyota Camry XLE Carpet OEM -cant find
Unable to locate 00208-32951-03 camry xle mat grey.
Anyone tried out 1997 -? which is the next model redesign. Does it have the passenger side hole? Tx |
Did you try the Toyota dealer?
I tried online (ebay) and oflline dealers. Some said they don't carry it due to the Toyota carpet issue. Not sure I believe that. Still looking.
Do a net search on the part number. Then call those dealers who list the part. The part appears to be discontinued but someone may still stock it.
The carpet issue was for later model cars around 2009. |
Thank you. Will check it out!
Still looking but actually put all four through washing machine. Surprisingly all turned out very well and all stains removed. Their better to look at now in the interim. It just the drivers is very worn but normal for its age. If your using a washing machine just be nearby. The mats are may be rough on the washing machine on spin cycles if not balanced right.
Rockauto.com will have one pretty cheap to
