Browse all: Lighting
- Toyota Camry 6th gen How to Replace Front Turn Signal Bulb
2007 Camry turn signals?
I want to change the yellow turn signal bulbs but I cant get to them. I've already changed every other bulb except those. What is the easiest way to take out the headlight assembly?The only way I heard is to take off the front bumper, is there an easier way than that? any help would be great.
thanks,
David
thanks,
David
RE: 2007 Camry turn signals?
Are the aftermarket headlights people are buying the same configuration? He's right about having to take off the front bumper though for the stock ones. Changing the fog light bulbs is a little bit of a pain too...got to take off the splash guard on the bottom.
Ok, what turn signal bulbs are you talking about?
The only ones on my 07 Camry are built into the light assemblies.
You don't have to take the bumper off for them...
There's no way I'll believe that.
I haven't actually attempted to take them out, but there's no way you have to take a bumper off.
Again, I'll keep you posted when I get a chance to look at them.
BUT, what bulbs are you talking about, to make sure I'm looking at the right ones....????
I just purchased a 2007 SE and changed my headlight bulbs to PIAA Superwhite's. I wanted to change the turn signal bulbs too and had trouble finding any DIY info, then was bummed because I thought it would be a dealer-only ($$$$) affair but NOOOOOO..........
It's actually pretty easy to do. I moved the inner fender liner (just bent/pushed it out of the way) and reached between the liner and the fender up to the light. You can see the bulb connector for the parking and side marker lights that way. I used Sylvania Silverstar parking bulbs, so they have a bluish/gray appearance when off.
Good luck,
Hoppy
Good luck,
Hoppy
Remove the bumper? How in the world have the carmakers designed it? What is your car and model anyway?I studied the stuctured of mine car and it doesn't have to remove the bumper. It only needs a new replacement of turn signal light, I think that's the problem of your car man.
peternguyen504
10-29-2007 08:47 PM
