2022 Camry SE - Courtesy door light
Our 2022 Camry SE courtesy door lights on both front driver and passenger side only comes with a RED reflectors :( Does anybody knows if the courtesy lights are pre wired?
I own a 2020 Tacoma and the bed lights are pre wired. ( I just bought the OEM plug and play bed lights) Thank you for the help. |
Might try Toyotanation.com in the Camry section.
i'll do try toyotanation.com. thank you for the help. i'll post if i find some facts.
Glad to help.
Take note, sometimes Toyota puts in the wiring but not the actual fuse holder metal retainer. Here the fuse box has a fuse slot but no metal electrical fuse connections. The slot is missing the electrical connections. |
(Post 107448)
Glad to help.
Take note, sometimes Toyota puts in the wiring but not the actual fuse holder metal retainer. Here the fuse box has a fuse slot but no metal electrical fuse connections. The slot is missing the electrical connections. I just found out from toyotanation that the courtesy lights SE , TRD LE are not prewired. :( Easy mod is a ghost light |
