Camry Forums - Toyota Camry Forum (https://www.camryforums.com/forum/)
-   Appearance (https://www.camryforums.com/forum/appearance-10/)
-   -   Airbag warning label removal (https://www.camryforums.com/forum/appearance-10/airbag-warning-label-removal-52840/)
Cpt.America 05-11-2019 02:19 PM
I have a 2019 xse, and like most people I can't stand the giant white and yellow airbag warning labels on the underside of the sun visors.
How are you guys successfully removing these? I've had some cars where a hairdryer will remove them. And others that had to be wiped with alcohol.... I don't want to mess these up.
So, right way to go on these??
toyomoho 05-11-2019 05:24 PM
Supposedly federal law requires the notice to be permanently installed on the visor. Some state the label is heat bonded.
The issue is the visor material may be damaged with removal.
Is the visor material cloth or vinyl?
If vinyl some are using rubbing alcohol, others Goo-Gone.
The internet has hosts of threads and videos on this but each model has its own issues.
Toyotanation.com has a few threads on this with mixed bag results.
