Old 08-27-2015, 11:20 AM
How-Tos on this Topic
Browse all: Lighting
Print Wikipost
Headlight & Taillight up-grade - Advice Plz
Old 04-11-2007, 09:28 AM
camry313's Avatar
Default Headlight & Taillight up-grade - Advice Plz
Hi .. every 1
Iwant to boost up the power of my headlight but without using xenon tech.
Am thinking about changing my H4 bulbs into another brand such as BOSCH which is maufacturing most of german car parts .. they have a brighter power bulbs ... I don't wanna use the 1s are sold in the accesories stores as they produce hight heat which causes melting wieres & damaging the power plugs of the headlight.
also about the taillights I found Philips LED's butI dont have any idea about using LED on my 1997 GLi Camry as on my old chevyI cant use them because it requiers a 2 tengisten hair type bulbbut as the LED functions as 1 hair bulb.
anyadvice for me ??
Old 04-11-2007, 02:09 PM
nodrogkam's Avatar
Default RE: Headlight & Taillight up-grade - Advice Plz
No other way to boost the brightness of the headlights without using bulbs that draw more power (unless you look into HIR bulbs), or HID's (if you use HID's you should retrofit your headlights with a projector to reduce glare and to better focus the beam of light).
Just installing LED bulbs into the tails will NOT make them brighter. If you are able to retrofit the housings with a custom circuit board and leds and use special resistors/relays, then you can do it.
ref: http://www.toyotanation.com/forum/sh...17#post1716617
if you simply install a bulb, it will probably work, but will cause the 'tail light out' sensor to trigger and you'll have that warning light on your dash lit.
Old 04-12-2007, 05:59 AM
camry313's Avatar
mmm ... thanx I will bare that in mind ... as for the head light am reading now more about on BOSCH site ... I guess I will give it a shot .. just to refresh the headlights bulbs as they are used for a long time.
Old 04-12-2007, 01:54 PM
nodrogkam's Avatar
i use silverstars. i wish they made silverstar ultras in the h4 size.
vin888
11-02-2007 10:13 PM
camry313
07-08-2007 05:38 AM
camry313
04-29-2007 05:01 AM
camry313
04-10-2007 01:27 PM
camry313
04-10-2007 07:11 AM
Quick Reply: Headlight & Taillight up-grade - Advice Plz
